Thread: New owner
Created on: 04/13/18 11:14 PM
RE: New owner
04/02/19 6:14 AM
Ok so I’m going air filter crankcase filter block off plates ecu dyno pcv?
Make sure you can do the PAIR removal/blockoff plates mod on the Gen 2 ZX-14. I could be wrong but I thought that was not possible on the Gen2.
Go with an aftermarket air filter if you want but it will only give you a couple hp on the very top end and probably won't impact your AFR at all.
Most flashers like you to have the PC5 on there to tune fueling so go with it as your tuner recommends. Go to a reputable tuner or don't bother. The dyno session will help but I doubt it will be much better than a good map from Guhl or someone like that.
RE: New owner
04/02/19 6:18 AM
* Last updated by: Rook on 4/2/2019 @ 6:18 AM *
frank851
RE: New owner
04/03/19 7:31 AM
I had the ECU flashed by Ivan's Performance Products. It runs great as the ECU flash was designed for the aftermarket exhaust. Very happy with the performance and the other features from the ECU flash over the stock ECU with all its restrictions.
2018 EMERALD BLAZED GREEN / METALLIC CARBON GRAY, Akrapovic Racing SS Full Exhaust System, Ivan’s ECU Flash, PSR Adjustable Lowering Links, PSR Kickstand, Screaming-Banshee air horn, Yoshimura Fender Eliminator, Heal Tech Brake Light Pro, R&G Racing Aero Frame & Front Axle Sliders, Passenger Grab Rail, HeliBars, Lowered Sport Foot Pegs
RE: New owner
04/05/19 6:18 AM
Awesome! Glad to hear Ivan is tuning the Gen2.
beck6
RE: New owner
05/19/19 9:56 PM
I also ordered a flash before, which is much better than the current one.
